Mach 3 HELP
I am having a problem with Mach 3, tried to move to another pc didn’t know about 32 bit-64bit must have messed something up on my old settings. Right now, when i try to cut something the router on my cnc either goes up to the max or down. Anyone has a solution.
I used to use mach 3 a lot on a couple of my cnc routers, but migrated to GRBL for the ease of use. I can’t give you any help but I would check those boxes and see if things are enabled or not.
