MacOS 15.7.2 unable to connect after system update
I have been using an Intel MacBook Air, Easel Pro and my Sainsmart Genmitsu 3020 Pro Max successfully for a couple of years with no problem.
However after a system update, Easel Pro no longer connects to my 3020 Pro Max despite the Carve and Jog buttons showing green.
Here’s my checklist, reboot between every step:
Updated System. :check_mark:
New install of Easel Driver. Successful. :check_mark:
Checked that Security and Privacy settings were not interfering. :check_mark:
Confirmed no pen tablet drivers present. :check_mark:
Check that the USB cable input and output working. :check_mark:
Confirmed that the System could “see” my 3020 on the USB Bus. :check_mark:
Browsers - Safari and Chrome - both set to allow Easel to access local network. :check_mark:
Carve and Jog buttons show green in both browsers. :check_mark:
However, only in Safari the Easel preview window is blank. ✘
Unable to carve or jog in either browser despite being able to go through the steps. ✘
No error message in either browser.
I know that Apple’s updates are increasingly strict on Security and Privacy settings and suspect this may the cause.
Also, some while ago I seem to remember seeing a Terminal command that released the USB Bus for “easel.com” in this space or maybe in the support pages - but I can’t find it.
I’ve got a load of Xmas projects half finished so any help or suggestions will be gratefully received!
