Need help with 45 degree design
I am trying to make a 45 degree connector as shown, but want the cut to be on the outside lines (make a whole piece). how do I remove the inside lines where the 45 meets?
Highlight both and left click then hit combine. Edit Sorry right click and pretty sure you need both set to clear out pocket to do the combine.
That did it. thanks Nick
I just tried it and it works for cut on path as well.
