NEW: Floor Plan Editor
We’re excited to announce that the Floor Plan Editor is now live in Easel Cabinetmaker!
Key features of this new update:
  • Create Custom Room Layouts: Easily draw walls, set lengths and angles, and design both rectangular and non-rectangular rooms by adding and editing points in the Floor Plan view.
  • Place Islands Seamlessly: Arrange island cabinets at any orientation
  • Real-Time Adjustments: Modify your room layout, and your cabinets will stay attached and adjust accordingly.
This new update provides more flexibility and customization and a more accurate visualization of each room that is sure to impress your next client.
Try It Out Today!
How it works:
  • Open up a new Cabinetmaker design, or one that you’ve already created. In the bottom-right corner of the design visualizer, you’ll see the 3D option is selected.
  • Click on the Floor Plan button, and you’ll be brought into the floor plan editor
  • Click and drag any point along the walls to reposition that point. There are helpful visual guides to show you the length and orientation of each wall.
  • Click anywhere on a wall to add a new point
  • Select a point on the wall and hit Backspace or Delete to remove it
  • Once you’re satisfied with your floor plan, you can click on the Design in 3D button to return to the 3D editor. You can go back and forth between the floor plan and the 3D editor as you are designing to make sure that your room is laid out exactly how you want it.
Log in to Easel Cabinetmaker and start exploring the Floor Plan Editor. We can’t wait to see the incredible designs you’ll create with this new tool!
We Value Your Feedback
After you’ve tried it out, please share any thoughts or suggestions you might have. Your feedback helps us make Easel Cabinetmaker even better.
Is there a way to adjust the wall height?
The Room dropdown is no longer there.
Hey, how to adjust wall height? And also how to switch to millimeters? Floor plan is not changing units regardless of setting on button.
I’m having the same issue with the wall height. There used to be a way to change that on the left side. I appreciate the layout editor, but it’s sort of useless if I can’t change the wall height. Am I missing something?
Hi Matt, you can edit the wall height at the top of the left panel
@John33 you can change the units in the lower left corner, and it will update all the measurements in real time:
Screenshot 2024-11-26 at 1.22.57 PM
Screenshot 2024-11-26 at 1.23.05 PM
Please reach out to me if you need 1:1 help, I would be happy to chat more.
Best,
Ben
Dumb question, you can’t seem to delete a wall once added?
These icons don’t update correctly once the wall moves around, Nook back wall should be the north icon not the south icon.
Has this tool been discontinued, I have not seen any updates or forums posts in a long time.
Hey Jason,
Our team is currently focusing efforts on growing and expanding our primary design and fabrication platform to best meet the needs of the makers using Easel. For the time being, Easel Cabinetmaker development is on hold, though the software currently remains available to everyone who has utilized it since its release.
Please keep us posted - the CabinetMaker tool is great (with a few glitches that are easy to navigate around). Just finished a Kitchen bench seat and floor cabinets combination. The Easel Tiling function on my X-Carve Pro worked great too - not a single hiccup in the whole build process.
