Not leaveing tabs when cutting through material
tabs are ticked on but not leaving tabs when cut
Double check that your depth of cut is all the way to through the material?
To add to this, if you have tabs on, make sure you aren’t cutting too far through the material so it’s just cutting the tabs away.
The default tab is pretty thin, if the piece is not secured down very flat, it’s easy for it to just too deep to leave the tabs.
When cutting tabs, you should be able to hear & see it cutting the tab. On the last pass (or two), you will see the machine stop, lift, move, and lower back down for each tab.
This issue has been resolved, thanks for your assistance.
fred
