Problem Starting at the Correct Point
Hello.
I have the FoxAlien Masture Pro and have been using the free version of Easel for the past two months. However, I have only had two successful carves, and this was due to user errors.
Once I learned what I was doing wrong, I started a new project, and it was going pretty well until the Z motor tripped and stopped working. I’m working on the detail pass after the rough cut. I set the router to the zero point it was at before (I mark where zero is on the wood) and sent it to carve. It now wants to start the detailed work in a different position in the wood.
I read that I should use the “use previous zero,” but I didn’t and don’t know how to get it to start where it should.
What should I do to get it back to the previous path?
I really appreciate any help you can provide.
