We added a right-click menu to Easel to make it easier to access the tools in the “Edit” menu. You can now right click to do things like send shapes forward/backwards and combine. Here is a demo gif.
Awesome, Love the frequent updates of Easel. Can’t wait to see what features come out next.
Context Menu = AWESOME!!!
Keep up the great work!
{:0)
Brandon
YESSSSSSS FINALLY
Was hoping for this to come! Really hoping for folders to come out soon
Folders would be great!
While we’re on the discussion of things that we hope will be added…
Can we get a CTRL + Click to select multiple items…
Having two/ more items over the top of other items (ie. multi-layered cuts) it becomes really difficult to select only those pieces desired. It seems like this would be a simple feature to add.
{:0)
Brandon
You can shift + click to do what you are asking.
THX Paul
Keep up the good work there
I´m looking forward to see if you can make all the
objects in easel in alphabetical order too
Kristian / Sweden
absolutely
I need that too
THIS! Thank you!
Thanks!!
I guess I never thought about the shift key. Normally for applications it’s Shift + Click to select all items between and CTRL + Click to select specific items leaving the ones in between not selected.
Either way now I know…
{:0)
Brandon
Just learned in Easel the other day that Shift + Mouse button one and drag, allowed moving the 3D view around (up and down, as well as left and right). Allows one to really zoom into the tool path. Thought I was stuck with only Control + mouse button one to tilt the 3D view. The 2 combined allows dialing in a great view as needed.
list of shortcuts…
https://inventables.desk.com/customer/en/portal/articles/2429543-easel-keyboard-shortcuts
Another one that I found accidentally is that on the “left” working window (not the preview)… the wheel button will move your screen up and down, and if you hold “Shift” + wheel mouse. the screen will move left or right.
I agree with Phil, this is common practice in CAD/graphic enviroments.
Another feature I’d like is to lock individual objects to their given position, eliminating the chance to unintentionally move it about.
Also, aligning objects relative to each other:
If I have two objects I’d want to center align to each other (not to stock) When selected they will center in a position somehwere between their starting points.
If I can select my reference object, SHIFT+click object #2 and them perform vertical/horisontal align only object #2 will move, into center of object #1 (reference object)
That is not a bug, that is the intended functionality. I’ve used software that did this before (I think v-carve) and thought it was very difficult to learn how to use, I thought there was a bug because I couldn’t select things consistently until someone told me about the left to right / right to left thing.
Also thanks everyone for the enthusiasm!
Having two actions depending from which way you drag will be confusing for beginners. I suspect that most of the people who are complaining don’t even use Easel as their main design tool. I personally would prefer a tool that is consistent.
