Scaling question
After importing a SLT file and setting sizing to actual piece dimensions when I ran the piece it scaled short exactly the size of the bit used. Example is a guitar neck, heel is 56 mm wide, and it ran 50 mm when completed. I also used the Full depth cutout option. Is that setup to route on shape path and if so, can it be changed to route outside path or is the only option to add in the diameter of the bit to compensate.
I would adjust the scale until it is correct on a test piece.
