Settings for black on white plastic engraving
Easel no longer allows setting the top surface thickness for two color materials, and also no longer shows in the preview. I’ve also tried Inventables two color materials with the same results. Any suggestions?
Thanks
If you want to cut through the top layer to expose the bottom layer, can’t you measure the layers and set the depth only to go through the top layer? That’s what I’d do on WBW or BWB pickguard material. Try it on scrap first.
