Shape pop up box
In the Shape/Cut box - can we get rid of the “in/mm that is after the dimension in the position and size boxes ?
If my number is 5 digits, the “n” is out of the box and I have to go back and highlight a second time to remove it.
We know if we are programming it in inches or millimeters. We do not need it in the dimension box.
Russ W
Just so you know, you can actually use almost any other dimension in the box and it’ll convert it on-the-fly. So even if you are using inches, you can type 18mm and it’ll convert it to 0.71in for you.
That being said, I agree it can be annoying to have to triple-click to highlight the whole box if you want to replace everything. If you double-click, it highlights either before or after the decimal point (at least on my Firefox/Mac setup).
I do wonder if it makes sense to not show the unit (or show it outside the box) as long as it’s the current configured unit.
