Here is some of my signs finished with glow in the dark
Looks good. Paint?
i use glow in the dark powder, with epoxy resin,and painted with tinted laquer
What type of glow-in-the-dark powder do you use? most of the (cheap) glow paint products that Iāve tried donāt seem to hold much glow.
Sakura brand āSolid Markerā glow paint sticks (or āSolidified Luminescent Paintā) are bright, durable and can mark on anything.
Quality pigment is expensive!
I would love to see a step-by-step for this process.
I would also love a step by step if you or anybody else is willing!? I know not everyone has time for that though!!!
Btw your work is very nice!! Looks very professional!
yes your right pigment is expensive, is around $25 for 4oz.but the glow in the dark pigment works very good for me, i buy my pigments in www.glomania.com and if you use a white background before applying the glow in the dark is more bright
i can share this process just i need take some time this week to take pictures or video
thank you Casey, i can share this process is very easy to make ill try to take some pictures or video this week i just finish this one
Thatās great!
Thanks!
Cool idea.
Thanks for sharing.
Please do ⦠I was getting ready to try some glow powder in epoxy to fill engraved grooves in a part, and am sort of stuck on deciding my procedure. I do metal powders now in epoxy for fills and that works well, but the glow powder is a little different beast, worried either a) too thick of an epoxy will prevent it from getting enough light, or b) too thin and itāll wash everywhere and the glow will be blotchy and visible even where you didnāt want it.
Torn between the normal T88 I use with the metal or something thinner like Mirrorcoat, although I suspect the thinner stuff might require constant stirring to prevent the glow settling out.
Also I currently use a heat gun to help āwarmā the epoxy with the metal so it flows into my engraving better - not sure thatās safe with the glow powderā¦
How about testing the correct amount on a test piece of material ? Just a small amount . Iāve used the glow in latex before . Itās a process to get the right consistency .
@HectorLuna what character is the 3rd and 4th one?
@RichardRemski i always make a test the glow powder in the epoxy before mixing with the hardener with a UV light i always use the yellow or green color powder those make more light and i put a white primer in the engraved piece to get more light
@Zach_Kaplan The 3rd and 4th is the same character just before paint and glow in the dark and after is finished and is RAINBOW DASH from MY LITTLE PONY was a gift for my niece
@HectorLuna - So if I understand right you portion out your resin (part A only), mix in the powder, test and maybe add more depending, then after you have the glow youāre after you mix in the hardener (part B)?
Good to know it can be done that way. With the metal powders I always mix A and B to combine very well, then add powder last (while the curing time clock is already ticking).
Not sure about the white backing in my case - I want to use some red/orange in a piece of mesquite and Iām worried itāll show at the edges of the groove too much. Will definitely let you know how it turns out (Iāll take blame if itās bad, and give you credit if itās good
) Iām after a fairly subtle glow for this particular piece, kind of like low glowing embers (itās for some of the lines in a firemanās seal), wasnāt even going to tell the recipient to expect it, itās hopefully a āwhat the heck did you do???ā surprise moment.
(EDIT: Iām after a daytime visible red/orange color, that also glows red/orange. Hopefully thatās what I bought a couple weeks ago, should be arriving this week.)
Perfect works! Iām Chloe from Glow Technoloy.If youhave any questions about glow products, please feel free to contact me.
There are two types of luminous powder, one is long-acting and the other is short-acting. You should be a long-acting luminous powder.You can take a look at this website, it is a website dedicated to luminous powder:GLOW IN THE DARK POWDER - glow in the dark powder | glow in the dark paint | glow in the dark stones | glow technology
