Is there a way to add or delete tabs for 3D carves. Specifically add tabs as I am wanting to do a carve but there is an area that is missing tabs and I don’t want the piece(s) to move and bounce off the bit causing a bad carve or snapping the bit . I know I can move the tabs around but need to be able to add, I have read the info on the 3D carve process and done one already but all the tabs where there on the other project. I do a combination of clamps and double sided tape to minimize movement but there is still room for error on tape placment .
The material I will be using is aprox. 2 in thick and that is why I have some concerns. see picture below on where tabs are missing and needed in the circled area.
