Here is a project that I just posted of a little box with spline joints.
I was needing something to hold tea bags and this does the trick and looks good doing it.
Take a look and see what you think:
Beautiful work. I like it. Are all 4 sides identical?
Very nice. I’m looking at making a pie carrying box before the holidays and I was going to just use traditional CNC finger joints, but I might have to give that another thought after seeing this…
Thanks @ErikJenkins
Yep, all four sides are the same. I originally has one with the divot and the others were straight across the top, but changed my mind in favor of simplicity and symmetry.
I love how the grain wraps around the box!
@sketch42, Thank you for the project plan! I made a Tea Box this weekend out of Oak. It does not have the same great colors as yours, but I like the way it turned out.
How did you get such a nice color contrast for your splines? Did you cut them out of a different wood?
Thanks! The same set up can be stretched or scaled for different size boxes.
Yep, I used a bit of kindling for the main box parts because it is cheap, but more importantly untreated pine. The splines were a different wood called Rimu but any contrasting type would work, or you could stain them before putting them in as long as it isn’t a stain that messes with the glue. Something like a coffee/tea stain or other water based stain.
Yours looks great BTW!
I thought about staining the splines first with a contrasting stain, but then figured I would just be sanding all the stain off when I sanded them flush.
Yeah you’d have to soak them in stain for a good while to get that kind of penetration… better off going with a different wood for a contrast.
