I am trying to adjust the font size. I can not find how to adjust it, except by the text size box and there’s no way to center all the text in the same box. could use help if anyone can help I would appreciate it.
Here, I selected the shape tool and placed a rectangle that was 8 inches wide and 3 inches high at the coordinate x=5, y=5. I made the position the center dot.
Next I went to the text tool and entered “Voila !”. I also selected the center position dot and set the coordinate to x=5, y=5. I changed the text’s width and height to be 7.5 inch width and 4.5 inch height. That way there is a little margin.
The text is now scaled to the rectangle and centered. You can group these shapes and move them around together as you need.
