Could it be possible to use the brass probe block to determine thickness. Example use the probe on the waste boar then use it on the project surface and subtract the two values. Possibly then allow a adjustment
I know that the goal of posting it to this category is to have it actuality integrated into easel.
But you can do this manually by probing and checking the machine machine position and recording that, then probing the workpiece and recording that machine position, then subtracting.
just a method if you wanted to use the double probe method before they actually integrate… if they even do.
