A while back I posted a question about cutting oversized pieces:
This is the item I wanted to cut:
It’s been a couple of months and I had some travel and all, so I just got around to completing that task, so I wanted to post an update and let you know how it went.
To recap, the sensible among us here suggested I use a japanese pull saw and cut the piece by hand.
Because I have an abiding faith in power tools, I was certain there needed to be a better way.
Also, I wanted a way of making a controlled cut in a scalable fashion as my workpieces get larger.
It seemed to me that I needed some sort of mitring capability, but was not sure how to accomplish that.
After much googling I had a list of 3 options:
All of them somehow involved chainsaws.
In the end I bought a ‘Beam Machine’, which is nominally an attachment for a chainsaw which allows for controlled linear cuts. It is normally used to enable cutting beams out of felled trees.
The important part here is that you guide the cut by settling the attachment on a 2x4.
This means that you are effectively guiding the cut, and by aligning the cut you can get the effect of a mitre box, without an actual mitre box.
I married it to a 16" 3.5HP 14.5V electric chainsaw. Works a treat.
Here is a photo collection of using this to make a controlled cut of a carving from the end of a piece fo firewood (click though…):
Now that I have done it, some notes:
- It is hard but not impossible to line up a cut on an irregular piece of wood which you have clamped to a table under a chainsaw on a hinge
- The chainsaw I bought, from Worx, had > 700 five star ratings on Amazon. One of the features is that it self-lubricates the chain. Also known as: the chain sprays oil. You may wish to cover the surface of the item you are cutting if you care about oil stains on the finished piece.
- Chain saws are fun.
So that is my update. Awesome fun. Hope you find it useful.
