Newbie question: my simple project involves 20 boards, each with about 100 1/2" through holes in 3/4" MDF. Does it make sense to use a 1/2" Forstner or other similar bit at slow speeds rather than a flute? A boring bit? Wouldn’t that be faster/more efficient? Thanks.
you would not want to use a forstner bit on the cnc machine they are not designed to do that
I would just pocket all of the holes and let it do its thing
if you had a 1/2" collet you could use a 1/2" drill bit
but I would just use a 1/4" end mill and spiral ramp into each hole creating a 1/2" hole
a brad point or dowel drill would work if you could find one in .5" or 13mm
http://www.toolstoday.com/p-5355-brad-point-boring-bits-57mm-long-10mm-x-27mm-shank-right-hand.aspx
Thanks for the advice.
