I
Is there any tricks to make these tool paths more efficient. More then half the cut time is doing unnecessary moves
I
you file has extra vectors that need to be cleaned up.
send it to me if you need help cleaning it up. PM works best if you don’t want to share.
All those points are holes
possibly you can share the file.
new 377 375 386.nc (214.9 KB)
Here it is
Found this GCODE Optimizer https://xyzbots.com/gcode-optimizer/
Had to edit the optimized file. Only had to replace all lower case with capitals for it to load.
optimised_new 377 375 386 holes.nc (85.4 KB)
