Hi all. Can you download an ini file for use in UGS 2.01 to control the x carve. cheers Josh
I believe the .ini file type you’re looking at is the UnrealGamesSync software and not the Universal Gcode Sender software needed to conrol the cnc. I havent seen a .ini files for use with the right UGS program.
Univetsal Gcode Sender can operate the Xcarve perfectly fine.
https://winder.github.io/ugs_website/download/
