is there a way to back or reverse back to something just had on Easel if you make a mistake? I’ll hit something like align and it will be be all wrong and I have no way of knowing how to undo what I just did. I don’t see like a back button where you just go back to before the mistake happed . Ive only had the machine for less than a week, so it may be a dumb question…
At the top menu bar for Easel you will find the Undo & Redo menu options under the Edit menu.
Edit: These will show up only when there are things to Undo or Redo…
{:0)
Brandon Parker
After you have made a move if you go up and tap on EDIT there should be a spot right at the top that says UNDO.
Now, I feel dumb…right at the top where I over looked a hundred times. Thank you.
No feeling dumb…
We have all been there; can’t see the forest for the trees sometimes at least until a branch hits you square in the face!
{:0)
Brandon Parker
Thank you… still trying to figure all this out! I never was one to use computers very much, I held on to my old cell phone for as long as I could. When I traded it in then put in the museum.
