I understand that organic material is not exactly reliable when it comes to mass production and certain applications. However, the issues I want to post here I do so out of the hopes that the situation can be improved or I can learn “how things work around here”.
Consider these: all of which are “supposed” to be 6x12 by 1/16th inch thick wood
Next, consider that the order consisted of 60 (30 maple and 30 cherry)
and that the work time on the table is about 3 hours for 3 boards at a time.
Because each of these pieces of wood are anywhere from 1/32nd to as much as 1/4th (+/-) each time a run is done I need to double check and create a test, then re-align the job and jig depending on how far off they are. Ended up having to make 3 different “spacers” to make em fit properly. Really increased the product time and slowed down the process.
Me and my client both laughed when we realized why all our cuts were all off on the 2nd and 3rd boards, we said “Must have been a shift change! lol. the guys that cut ON the line are gone for the day and the other guys who cut NEXT to the line finished their run”
Fine, so be it. Humans did it, I get it. But… now “measure twice cut once” has become measure 60 times and make new jigs, then change the artwork out and double check the board alignment.
I kind of feel like these should be "6x12 - 1/16th with LESS than 1/32nd of a variance… Anyway - the following series of thoughts come to mind, some of which are questions:
- Is this to be expected every time I order?
- Is this a fluke, only an occasional thing that is not the norm (lets say 3% of all orders are fubar like this)?
- Is this considered an appropriate margin of error on wood from the inventables Shop?
- In general can I expect this from any/all manufacturers on wood products?
- Any other suppliers that people can recommend?
- Can we get a big red disclaimer on the product page that warns us “these will be a little off, all of them, they are cut by hand to keep prices low for you (or whatever the case is)”? (would have been nice knowing what I was about to get into on this job)
