when I was duplicating text it went way off the work page and went very far to the right totally off the screen so far when I zoomed as far as possible it didn’t show when I brought up the cut path two lines went off the page. I spun the sample around and it showed the missing text. I couldnot find a way to delete it. How does one get at this text.
Welcome to the forums
CTRL+A will select everything in the project.
If you can select it you should be able to delete it.
Thanks, it worked…
