does anybody have any idea how to fix it???
shave it down with a half inch or greater bit…do you have your center brace installed???
you’ll lose your lines but thats what a square is for
I agree with @RonSommers looks like the center brace is gone or you are setting on a hollow bench.
The center brace is good but I’m thinking the table that its sitting on is not that great I’m about to order a couple extra braces from inventables to put extra support on the board
While there are lots of people that will cut into their “spoil boards” and or resurface them, I have never been an advocate of doing this.
I have always considered it the “bed” of my machine, and as such it should be completely flat.
However, because of the inherent problems of movement with MDF, I have replaced my bed with aluminum fixture plate.
I ALWAYS use a piece of hard board under whatever I’m cutting to protect the bed. (I did this even before I replaced it)
My Z zero is always from the top of my work piece.
1
Reply
I use a 1/8 piece of MDF as my pad for my cuts. Then after it has lived its life I use it for cutting stencils.
1
Reply
JanVanderlinden
Nice setup.
Reply
JanVanderlinden
I’m looking to go to the aluminum bed as well. Florida humidity is making it impossible to keep the MDF from changing daily.
Reply
Bobby,
Take a look at ATP-5 cast fixture plate.
That is what I used for mine.
It has the same specification as Mic 6 plate but cheaper. (your not paying for the Alcoa name)
My whole machine is within ~.005"
Drew.
Thank you.
1
Reply
Jan, What is the price range?
Reply
Steve,
Its been a couple of years but if I remember correctly it was around $250.00 ish.
I don’t know what size machine you have, but mine is a 750 and I still have the machine print with all the hole locations.
If anyone is interested I will gladly share it.
2
Reply
What thickness did you get?
Reply
3/8"
Reply
