Why aren't my accessory commands working?
I’ve gone into my machine settings, and I see the checkbox for sending accessory commands, was not checked. I had it check off, months ago, and my dust collector was kicking in and out, just as it should. But now, I see it is unchecked. I think that may have happened when I did a BIOS upgrade to the machine.
Any way, it’s now checked. I started a carve, and the dust collector kicked in, as it should. However, at the end of the carve, the collector never turned off. I think it’s command “M9” that turns it off, right? Why would my machine not be sending a M9 command, even tho it seems to send a M7 and M8 properly (M7 M8 = turn on dust collector) ?
Also, when I go into the Machine Inspector, shouldn’t I be able to type in M9 right there, and it would kill the dust collector? When I manually enter M9 and press enter, my dust collector stays running.
XCarve Pro
SCAM ALERT!
Support, can you immediatly investigate this previous post? It appears to be a phishing scam to a credit card site.Please look into it, and keep this this forum safe !!
Please report that you’ve seen this post, after action has been taken.
Pardon my ignorance, but when it is working, how does it work?? I’ve long wondered if there was a way to automatically turn on and off my dust collection without having to use a remote (which I’m lucky enough to have). While speaking with a rep from Inventables two years ago, I suggested that it should be possible to do so. I was told that he would pass the suggestion along, so I assumed that it was not possible (there is that ‘assume’ biting me again )..
