How come when i do a text cut it come out fine.
I then do the same cut on a new piece of material everything is cut slightly larger even though no setting have been changed
Are you using a v-bit? If so, are you adjusting the height every time?
If you cut using a v-bit, then put a piece in that was slightly taller than the previous one, you’d end up cutting deeper, which makes the letters slightly bigger.
This is just a guess, though, I’ve never had an issue with inaccurate sizing on my machine (an X-Carve Pro).
Thanks for your reply.
It was a damaged colett all sorted now thanks
Oh, that’ll do it. Glad you figured it out!
