Working with Nylon 6
Hi guys,
Did any one of you worked with Nylon 6?
What RPM, tool, feed, plunge, depth per pass combination is best?
I have tried a lot of combinations and ending up melting material…
Thank you for your help
=> Lower RPM and/or higher feed rate
thank you
Feed Rate:100–200 mm/min However, other data can refer to this:The Benefits of Using Nylons in CNC Machining for Precision Parts - Want.net
