After I uploaded a new firmware, worked
my Z-Axis again.
Even the other directions but..
Now it’s the wrong direction for all of them.
Where do I change the directions?
If you remove your machine from Easel, you could re load it and go through the motions of direction settings or:
- 1. Connect and Access Machine Inspector:
Power on your X-Carve and connect it to Easel. Open any project, then go to Machine > General Settings > Machine Inspector.
- 2. View Current Settings:
In the Machine Inspector, you’ll see a console window. Type $$ and press Enter to view the current GRBL settings.
- 3. Change Settings:
To modify a setting, type the desired setting (e.g., $100=115) and press Enter. The console will display “ok” if the change was successful.
- 4. Verify Changes:
After making changes, type $$ again to view the updated settings and ensure your changes were saved correctly.
$3= is for direction changes
The easy way to invert an axis is to redo the machine setup (machine>setup new machine) and then when you do the setup there is a page (its skippable so don’t skip it) where you need to test each axis and answer a simple question. Based on those answers easel automatically corects the direction of each axis by adjusting grbl setting $3.
