Hi all,
I’ve been trying a new toolpath strategy on our shop X-Carve for a little while now. Yesterday I used it to produce a part from 6061 aluminum.
I figured I’d share my success here and outline how I created the toolpaths.
I used Inventor HSM to generate the toolpaths, but Fusion 360 will do the exact same thing and is completely free to hobbyists.
I started by adding tabs and surrounding material in the CAD model.
Then I switched over to the CAM section and selected 2D adaptive milling. This is a toolpath strategy developed by Autodesk that utilizes trochoidal milling techniques. From what I understand it attempts to keep a consistent load on the tool by keeping tool engagement consistent. In other words, if the first pass of your job seems OK the rest of it will probably be OK too. I was able to take much deeper passes with this strategy and increase my material removal rate by about 10 times over traditional toolpaths.
I made separate toolpaths for the large circular pocket, small circular pocket and cutout. The important settings were:
Feedrate = 40 in/min
Optimal Load = 0.5mm
Maximum Roughing Stepdown = 0.5mm
Then I made a “Bore” toolpath for the mounting hole. I used the default settings but changed the pitch to 0.5mm.
I used the grbl post processor that Autodesk provides to produce the G-Code.
Overall the job took a little less than 4 hours. The finish is pretty good, especially the bottom surface of the pockets. I used a cheapo air pump from our laser cutter to blast chips away and a small squeeze bottle to apply cutting fluid to the workpiece.
You can see a video of the job here:
Here’s the part after peeling away the “onion skin”, sanding away the tabs and using our deburring tool to clean up the bottom edge.
Here are some things I will try on the next attempt:
- Add finishing passes for the vertical walls
- Reduce the pitch in the bore operation
- Extend the cutout and small pocket depths to get rid of the “onion skin” and cut the part out cleanly
