Xcrave pro. Stripped threads on motor. Fix?
How do i fix threads. Collet nut over
overtightened. Can Threads piece be replaced?
There is a good chance that just replacing the collet closer will allow the spindle to be sued again as the spindle is harder than the collet nut. But if just replacing the nut dorsn’t work then the assemblle is available on
71o3ovbbet-how-to-install-the-er-11-collet[1] (40.3 KB)
amasoon or others.
I am sure there are better one but it’s a start.
Precision ER11 Collet Chuck with Motor Shaft Spindle Spacer Sleeve/Shaft Extender for CNC Milling - Steel Collet Holder for Enhanced Deep Processing - 8MM Inner Diameter : Amazon.ca: Tools & Home Improvement
