Can anyone tell me what the xploder app is used for? I really cant figure it out if you could provide examples that would be great
Someone take me to school like it was 3rd grade!!!
thanks
thanks
hey jeff you know I checked that post out before I posted this one and it really didnt tell me anything I know it says that it will break up whole svgs into multiple ones but i cant get it to work
per example it wont break this svg up and this svg is available in easel itself
@Ruwan, would you want to explain a bit more about how your app works? maybe an “official” description?
Jeff
Say we have a shape made out of a set of non-overlapping shapes (islands).
The Xploder app can be used to divide (explode) the shape into its non-overlapping shapes. For example as shown in the following animation, the text ABC could be divided into its letters A, B and C. That helps us to work on individual letter.
Similarly, the app could be used divide a svg as well.
Most importantly, inner shapes of each non-overlapping shape stays with it. For example, the triangle shape inside A is part of letter A.
@WorkinWoods unfortunately your svg contain only one island, so Xploder could not process is further.
oh okay so how do we figure out how many islands our svg’s have? and is there another way to break a svg like that into more than one part?
thanks for the gif
@WorkinWoods, you could look for outermost boundaries. If you see only one, that means, you have one island. If you get N number of non-overlapping outermost boundaries, you have N islands.
For example following drawing has 3 non-overlapping boundaries, hence 3 islands.
Can someone please tell me how to split a letter so I can insert text between the upper & lower parts of the letter…thanks in advance
You really don’t need to split it - just cover it. First, place the letter on the work space. Then draw a rectangle the size you want the void space to be and place it over the letter. Then use the depth of cut slider to make it zero depth. The rectangle will change to white and mask/hide the desired area.
If you want it to look like the one in your photo, then draw the horizontal lines and place them at the top and the bottom of the rectangle and adjust their depth to the same as the letter. Next create the overlay text and place it on top the rectangle.
This is called “layering” and is a very useful method of creating designs. If you create an object and want to move it on top or behind and existing object use the “edit” drop down menu and select one of the “Send Back” or Send Forward" commands.
