Is there a way to use an XYZ probe in Easel? (the one with the hole)
You can use the Triquetra touch plate using Easel. You could get the software from Truquetra and should be able to use the XYZ probe with a hole in it, is the bottom notched out so it will fit on the corner?
Thanks, I will try that! Yep, the bottom is notched oud and fits on the corner…
EDIT: unfortunately I have no access to the download section…
