I have the X-Carve and I’m wanting to make some legend plates for work the material is aluminum 0.06" thick, the parts are 55mm x 55mm with a 30mm hole in the middle. I’m trying to get the correct bit to use and FR, PR and DPP any help is appreciated.
Hello,
For cutting aluminum 0.06" thick on your X-Carve, I recommend using a 1/8" carbide end mill . Here are some suggested settings: hpinstantink com
- Feed Rate (FR): 1200 mm/min
 - Plunge Rate (PR): 76.2 mm/min
 - Depth of Cut (DOP): 0.1-0.2 mm per pass
Make sure to use coolant to prevent overheating and ensure smooth cuts. Test these settings on a small piece first to fine-tune them for your specific setup.
Best Regards,
Ellen Hogan
Howdy, I sometimes use Easel to engrave 1.0mm (0.04) thick anodised aluminum tags.
Cut Depth: 0.1mm (0.004in)
FR: 200mm/min (7.9in/min)
PR: 100mm/min (4in/min)
Bit: 1/8 Tapered Ballnose - 2 Flutes, Radius 0.25mm x Shaft 3.175mm x Cut Length 15mm (0.01in x 0.125in x 0.6in). Advertised taper angle: 5.5 degrees (11 degrees total angle).
My 3018 is a baby compared to an X-Carve but early on I managed to brake a bunch of tiny end mills trying to get fine details and nice ‘floors’ in the engraved pocket.
Then I came across tapered ballnose bits, hooray.
By setting Easel’s* bit diameter to 0.3mm (0.012in) I get a lovely finish. No burring, shiny patterned floor and not a single broken bit since.
*I’m just thankful Easel will accept such a ludicrous bit diam ![]()
I’m currently torturing myself with the next size up 0.25in bit by trying to learn to do v-carve inlays ![]()
