Surfacing a project
Has anyone used their ex carve to plain to surface and level using a surfacing bit? If so, how did you use the machine to do it?
I drew a toolpath from front to back and shifted it from left to right. There is a website for inputting the pertinent info and generating gcode too.
G-code generators for facing (CNC)
I bet you could do the same kind of thing by drawing a huge rectangle in Easel and Clear out the pocket to a depth.
Yep, rectangular ‘pockets’ in Easel is how I do it.
I need to plane the surface of both pieces of inlay projects.
To deal with the radius this leaves in the corners, I make the rectangle a little wider (by at least the diameter of the surfacing bit) and I also set the bottom-left zero to be half that distance to the left.
I have not wasted the time to make tool paths. If you shut the machine down, anchor your work piece, install your bit. I have surfaced my work, by manually moving the X,Z, and Y until I had parallel edges, then ran the rest through the planer. It takes much less time and much less headache.
I did this for the first time yesterday. I’m new to CNC but I’m eager so, using a 1" resurfacing bit, I put my machine in “jogging” mode and manually removed 1/4 inch from the surface of a 2" thick, 20" x 14" piece of Maple.
